I’ve downloaded a file which is a WinRar. When I try to extract it, an error occurred the extraction was aborted, when I’m downloading this file the connection was never interrupted. I’ve downloaded the file again but it gives me the same error. Can this error be fixed?
Any suggestions would be appreciated.
WinRAR: Diagnostic messages
Message
C:DownloadsMS_setup053.zip: CRC failed in MS_setup053.exe. The file is corrupt.                                        Â
mjay3k
5 points
Corrupted zipped file when extracting
Hi Vivian, the file you just downloaded was already corrupt. If you have other mirror site to download to please do so, If not then we'll try to fix the file which you cannot extract. First download a rar repair program, you can search the net for free downloads but always look for a free version so you won't get any viruses. I recommend the RAR repair tool which is fast and accurate.
One you downloaded the RAR repair tool, open it and locate the rar file you just downloaded then click recover/repair, w8 till finish. Try to open the extracted file and verify if the file is working and you can open it.
