Corsair Adds Wireless Headsets, PC Cases to Vengeance Gaming Line
What type of battery is being used in Vengeance 2000 Wireless 7.1 Gaming Headset's? What is the exact weight of the Vengeance C70 PC Gaming Case? And I just want to know if all Corsair Vengeance Gaming Peripherals and Audio Products are compatible with Windows Operating System?
Answered By 5 points N/A #155743
The battery used in Vengeance 2000 Wireless 7.1 Gaming Headset is a lithium battery. Which is inserted inside of the Headset and it can perform for a long 10 hours backup.
It can be recharged by the USB cable provided with it.
It is compatible with Windows 7, Windows Vista and Windows XP all versions.
The weight of Vengeance C70 PC Gaming Case is not mentioned anywhere. But it could be less than 5 kg. If you are wiling to buy the Vengeance C70 PC Gaming Case online and worried about the shipment cost, you can visit any online shop of CORSAIR and follow the procedure.
The products of CPRSAIR especially the Audio Products they have 3 type of product in the store and all are compatible with windows OS. If you willing to visit the product and its features go to the foiling address:
http://www.corsair.com/en-us
On the other Hand in the case of Vengeance Gaming Peripherals Vengeance Gaming Mice, Vengeance Gaming Keyboards and Vengeance Gaming Headsets are compatible with windows OS.
http://www.corsair.com/en-us/landing/new
But the Vengeance Gaming Cases needs the ATX and Micro ATX motherboards. Without the ATX motherboard this will not work. If you willing to visit the product and its features go to the foiling address:
http://www.corsair.com/en-eu/cases/vengeance-series
