Cost of Microsoft Smart Glass
Microsoft Smart Glass will cost around 8500 to 9500 PHP if it will be released in the Philippines. This application can be installed on all android, IOS and windows devices that could probably change your gaming style.
Smart Glass also serves as a second controller which will basically turn into a multimedia hubdevice that willdriveyour videos and sounds of your Xbox and media devices into greatly powerful features. Moreover, it works with Movies, Tv Shows and Internet Explorer Browser. Xbox Microsoft Glass is reported to be released on mid or late of October this year.
This application truly will rock your world!
The Xbox SmartGlass is not literally a glass or a screen that you’ll fit on your monitor. It is actually an application that you can use on your computer, tablet, and iOS and Android Smartphones. The good thing about it is that it is totally free. So, if you’ll ask how much it will cost you if you’ll purchase it in your country, the answer is nothing.
It will cost you nothing to have it on your device. You only need to download and install it on your computer, tablet, Android, and iOS Smartphone. The Xbox SmartGlass is an application that will convert your Smartphone and devices into a second screen that will intelligently interact with your Xbox. For iPhone and other iOS devices, you can download it from Xbox One SmartGlass for iOS.
It supports iOS 6.0 and higher. It works on iPhone, iPod touch, and iPad. For Android Smartphones and devices, you can download it from Xbox One SmartGlass for Android. It requires Android 4.0 and higher. For tablets and desktop computers, you can download it from Xbox One SmartGlass for Windows.
Your device and or computer should be running Windows 8 and later. For Windows Phone, you can download it from Xbox One SmartGlass for Windows Phone. Your Windows Phone handset should also be running on Windows 8 and higher.
Check out this Techyv post too because this post is also addressed your problem.
