Could anyone say what is mean of super()
In Java, super() function is mainly used inside the constructor to invoke the constructor of parent class (superclass). We use the super() function to initialize the variables of the parent class or sometimes we need to pass the parameters to the constructor of the parent class from the derived class.
For example: The following class make a call to super() function inside its constructor to invoke its superclass constructor in order to set the title of the created frame.
public class MyWindow extends JFrame {
// Constructor
public MyWindow(String title) {
// invoke the constructor of superclass
super(title)
In this example, when a instance of the class MyWindow is created, its constructor will invoke the constructor of the parent class and pass the variable 'title' as its parameter.
In Java super keyword is used to point to the superclass instance. If you want to invoke a super class constructor or access a super class data from a derived class, you use the super keyword.
This example shows how to use super to access the super class data inside a derived class.
class Base
int t = 10;
class Test extends Base
public void m()
System.out.println(super.t);
In Java, the 'super' keyword is used to call the parent class's constructor, with arguments if desired, using the syntax
super(arg0, arg1, …). The restriction is that it must be the very first line in every constructor unless omitted, in which case
It will be automatically inserted without arguments
