I am planning to buy a DS with processor arm v9. I would like to know how flash player arm v9 works? Was it optimized to view YouTube videos? Or can I actually play flash games without the hassle of conversion? I need to know your opinion and it may affect my decision to buy the product.
Could flash player arm v9 allow me to view Youtube videos?
All flash players including arm v9 can view YouTube videos. It is compatible with any flash that you encounter on the internet. If your DS is equipped with a flash player or flash software. You can do almost anything with the flash that you will found on the internet.
You can play flash games, watch YouTube videos and so much more.
Although the Nintendo DS runs on an ARM9 process, it cannot play YouTube videos from its built in browser. Unfortunately, all of the Nintendo DS line does not support flash player out of the box. There are applications that can convert these files so you can play or use them on the DS, but this is with conflict to your "without hassle" because you have to tweak the console a little bit. This also applies to playing Flash games from the internet. You need to convert them in order for you to play it on the DS.
