Good day.
I am a father and knows just a little about this so-called router which provides an internet connection at home. I was planning to monitor data usage dlink router of my family at a certain point of time for references. Is there a certain process which I could follow to set up my goal?
Or a software to be downloaded?
Thank you very much for your time spent.
Could I monitor data usage link router on my Personal Computer?
Hello Kristopher,
You need not be a computer nerd to achieve that goal of yours. I am sure your Dlink router should have data tracking capabilities preinstalled. I'll advice you check your user manual or the installation software to confirm it does have.
If yours haven't, never mind. There are third party software's you could install to help you monitor your data. Some of these programs have various features; from tracking bandwidth usage to archiving sites visited. I propose you use Router Monitor 0.93 Beta as it will work perfectly with your Dlink router. It is very easy to use due to its user friendly interfaces and ability to run on any Windows OS http://www.softpedia.com/get/Network-Tools/Network-Information/Router-Monitor.shtml.
Here is another option if you wish to do some exploration.
PRTG Network monitors: This 3rd party software gives you the same flexibility as Router Monitor 0.93 Beta. It monitors your bandwidth, provides alerts for networking breakage available it is even available in various languages. It is also available as a downloadable freeware https://www.paessler.com/prtg.
