Could I use Gmail as mapi in Windows 7?
Here's the thing, basically I would want to use Gmail for mapi in windows 7, mapi being considered as a messaging architecture and a Component Object Model based API for Microsoft Windows, is this possible or is mapi basically running or already available on the windows 7 package itself? I hope someone would enlighten me.
Thank you.
Answered By 0 points N/A #148923
Hi Leslie Joshuaa,
Microsoft decided not to support 'Simple mapi" on gmail system in window 7. Although countless applications use it to manage emails,gmails including 2ic pallets. A replacement system has not yet being provided.
Therefore window 7 users have this option:
1. Create Gmails/Emails messages manually by copying and pasting information from the '2ic.Gmail.txt' this file is created when there is Emailing error i.e. every time you Gmail with window 7
2. Downgrade by following this route 'C:windowssystem32mapi32.dll' file to the earlier version, i.e. replace mapi32.dll from window XP or Vista with the same file.
NB
Downgrading seems to work ok, Mapi32.dll on windows 7 version no: 1.0.2536.0 which is the same as Mapi32.dll on vista & XP windows.
I recommend to only rename the existing Mapi32.dll file rather than delete it just incase other programs do not work after downgrading in order to restore the previous Mapi32.dll
