Could a Network magic pro setup my ADSL router?
Hello techyv.com!
I have here a laptop, and an ADSL router. Now I've formatted my laptop like a while ago, and just noticed that I've lost the installer of my ADSL router. Now I was thinking of some other ways to install it, I'm planning on downloading Network Magic Pro from somewhere with a connection and use it for my Laptop. Would a Network Magic Pro fixed my problem? If not please let me know something that I could do to install it without a CD.
Best Answer by Marcos P Blake
Answered By 30 points N/A #165576
Hi Geroo,
Well when you format your gadgets like desktop or laptop, the network and other utilities also removed from that system.So, you need to install it through your Motherboard CD, which has been only manufactured for your's motherboard and doesn't work with other Motherboards. So, the best thing if you use your own Motherboard CD. If the Network Magic Pro works for you then you can try it.
Answered By 55 points N/A #165577
If you want to reinstall that firmware then you have to use the CD of the router if you have. Otherwise you can also download it . As it is a universal driver but may possible that it cannot work in any of the PC.
Magic pro is also a best one for this purpose. But you have to buy that one for your management.
You can get it from the link below.
Magic Pro
