Could not able to play great escapes solitaire for Mac
I downloaded great escapes solitaire for mac but when I use other applications simultaneously with it, this game got hanged. Should I reinstall it or there is a problem in mac ?
hello, of course you can try the reinstallation, but here the main problem is that solitaire can be uncompatible with mac. Or in the case of reinstallation you can try to download if from different browser-different apps can work and be downloaded differently in browsers.
You don’t need to reinstall the Great Escape on your Mac. Your Mac may not have enough memory to allow more than one program to run simultaneously. Please check if you have enough memory on your computer.
Please check whether you have installed the latest and genuine version of the game onto your Mac.
Also check if the program is compatible with Mac OS.
Make sure the other program that you are trying to run with Great escape is compatible with Mac.
This should fix the issue.
Thanks and regards,
Skarbos Jay.
Notifications
