Could not backup file while installing update
Hello friends,
I have this game Assassin’s Creed Revelation, got a message that they have patch file for this. So tried to update this game, but it is in the process got an error message and it stopped in the middle. So I tried again but no luck and now I am not able to play the game either. Please assist me fix the error.
Couldn’t back up file F:GamesDataPC_ACFE_Cappadocia.forge to file F:GamesPATCH_BACKUPDataPC_ACFE_Cappadocia.forge
Answered By 10 points N/A #178270
It seems that the problem is due to the patch file of the game. I suggest you that first delete your patch file and then should try to run the Assassin’s Creed Revelations game. Uninstall the Assassin’s Creed Revelations game from your computer but check that all the game files and patch files have been removed properly. After this, restart the computer and then reinstall the Assassin’s Creed Revelations game again in your computer and then you have to check whether your problem get solved or not. Another thing you can do is download the update file from the net and apply that update file and then start the Assassin’s Creed Revelations game.
Or, what you can do is try to run the setup as ‘administrator’ by right clicking the mouse and then ‘run as administrator’. Hope this helps you to solve the problem.
