Could not complete ARO 2012 download
I could not download ARO (Advanced Repair and Optimization) 2012.
The download process always stops when in the middle or before the process ends.
How can I fix it?
How can I fix it?
Please follow the steps below that I used to download ARO(Advanced Repair and Optimization)2012 to be downloaded successfully:
1. Use windows 7 Ultimate.
2. Use Firefox from version 7.0.1 not older.
3. Check that your download is not blocked.
4 Go to this URL and click on Download now using CNET secure download.
5. If there is any problem with the download then try to download cnet installer first to be used in download ARO 2012
6. Also try to download the file during off-peak hours.
7. Please save your file first onto your hard disk not running it directly from the downloaded link
 Dear Halley,
Please use the below mentioned steps in sequential fashion to resolve the issue.
Step1: Use a different web browser.
If you are currently using Internet explorer as a web browser using Mozilla Firefox, Google Chrome, etc.
Step2: Allow Popup windows and cookies.
Allow third party cookies on your browser and also enable pop up windows
Step3: Disable Firewall and Antivirus Software.
Temporarily disable firewall or any Antivirus software
Step4: Ensure that the downloading is being performed locally and not on the network drives.
Step5: Clear the temp directories to ensure more free space is available.
Step6: Enlarge the temporary Internet Cache.
Wish you good luck
