Could not create all defaults on Integration Manager
Recently, I installed Integration Manager on my System and getting this error message when I tried to launch Integration Manager. Do you have any idea to fix this problem?Please share solution to resolve the following matter. Any help would be appreciated. Thanks in advance.
Integration Manage
Could not create all default application data due to the following error: Access to the path C:ProgramDataMicrosoftMicrosoft Dynamic sGP11.0.0.0’ is denied.
Access to the path C:ProgramDataMicrosoftMicrosoftDynamic GP11.0.0.0’ is denied.
Answered By 0 points N/A #170842
Resolution:
Start Integration Manager by Right-Clicking on the Integration Manager shortcut, and then choose "Run as administrator".  This will start Integration Manager using the Administrator access token that will give the application the sufficient rights to create the directory structure mentioned in the error message and then write the default configuration file.
Tyler
