noel_dy
20 points
Posted on - 09/16/2012
Please I am in need of help. Graphics problem just came up. How do I fix this so it would work? I would be grateful of your help.
Could not detect any suitable screen modes
Probable error in graphics driver.
Thanks,
Noel
Could not detect any suitable screen modes: error in graphics driver
Hello Noel,
To resolve that issue, you will need to try the following:
First, open cfg.txt and then look for the Resolution screen. You will need to put 800×600 and then save the changes, and then try again.
Another workaround will be to reinstall the latest directx update and see if it will resolve the issue.
Carl
Hi there user:
This is an error of Graphics Driver.
Maybe the DirectX wasn’t installed yet, and/or if it is installed already, it could be damaged. If you don’t have it DirectX yet, here’s the link to download http://www.microsoft.com/en-us/download/details.aspx?id=35
Note: Make sure you are using an appropriate Graphics Card.
Make sure that the cfg.txt and LFS.exe should not be in the same directory.
Thanks for asking here at techyv.com
Best regards,
