I am trying to use Texture compression to resolve the problem of texture size limit but when I attempt to do this act the following error message occurs. I have tried different ways to fix it but could not find any result. I need your assistance. Thanks in advance.
Error
Could not find any tileset textures, are you sure that iso is NSMBW??
I think, because you did not mention the name of the program, you should consult with your manual or with the application’s guide. Since I think the program you are using is a graphics editing software, check some online tutorials if you are just beginning to use the application. If it is an Adobe product like Adobe Photoshop 7, Adobe Photoshop CS2, and so on, visit the Adobe website to learn more.
If you are doing it correctly after checking with the manual but the problem continues, try reinstalling your application. Also, if you are using an old version, you should update to the latest version.
