Why I could not install my CaseWare templates?
This error message would not allow me to install it. Error Code: 45
CaseWare Template Packager
File decompression failed. File path is invalid or file is corrupt. Aborting
operation.
Error code: 45
                                       OK
Could not install my CaseWare templates : Error Code: 45
Hi Raymond,
To solve this problem you have to ensure CaseWare Working Papers is installed.
Also, you must ensure the correct version of CaseWare is installed in your machine.
From what I've gathered regarding Error Code 45, you must ensure there are no instances of Packager open by loading your Windows Task Manager. To open WTM, hit CTRL + SHIFT + ESC on your keyboard. In Processes tab check for cwpackager.exe.
If it is present, select it and press End Process.
Now try to install your CaseWare templates. It should work neatly.
Best regards to you.
