jake murray
Posted on - 01/15/2012
I am trying to install System Suite Pro 11 on my Windows 7 PC. I got a message that I have to uninstall McAfee to continue the installation since System Suite comes with McAfee Internet Security Suite. The problem is I do not have McAfee installed on my PC. And yet, I cannot continue with the installation. Is there a way to install this without having to install McAfee? If so, how can I do it? Help me.
Could not install System Suite Pro 11 due to McAfee
Hi Jake,
To check if you do have McAfee internet security suite, you can go to Start > Settings > Control Panel > Add/Remove Programs > Look for anything that says McAfee Internet Security suite. It may also be due to other Security suite or Antivirus application that is installed on your computer. You can try to check on your Programs if you have a different antivirus installed. Look for Norton, Kaspersky Sky or AVG internet protection. This may be the one causing the problem but it is only displaying McAfee on its message.
You can try to remove the antivirus you have then restart your computer for the changes to take effect.
Aristono
