Marco P Hamm 130 points N/APosted on - 04/15/2014
Hello experts,
My new game Prototype 2 Engine have this error and sadly I can’t play it. I’ve been waiting a long time for this game to appear and now I am disappointed. Can you experts help me to play the game without any error and any problem? If I install some new games I will have the same error?
Thanks!
Main Win32
ERROR: Could not load DLL ‘prototype2engine.dll’. You probably have a static initializer that is crashing.
The most common cause is forgetting
core: :Name5tringAllocationstatic in a static core: :Name:
static const engine: Name Foo( “Bar”,
core:: NameStringAllocationStatic);
Or verily that the DLL exists. You can debug the issue by running your ‘main’ project with the command line: >><<
It is a DLL error on the game so probably it is not compatible with your operating system. So, you need to check if your current platform supports the game Prototype 2. The game “Prototype 2” is also available on Steam and can be downloaded from Prototype 2 on Steam. If you are running an operating system earlier than Microsoft Windows XP, the game will not run.
Prototype 2
Prototype 2 supports Windows XP, Windows Vista, and Windows 7. Besides your operating system, you also need to check if your hardware can support the game and it meets all the requirements because hardware incompatibility is also another cause why a program can’t run. For Prototype 2, you need to have at least 2.6 GHz Core 2 Duo or any equivalent AMD processor, 2 GB RAM, and a video card with 512 MB video RAM.
If you meet all these requirements then you can run and play Prototype 2.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
