I recently installed the latest version of EvernoteWM_3.3_64861 on my Dopod with Windows Mobile 6.0. But I could not log in or see any kind of notes. The screen is showing an error message: Error occurred while interaction with Evernotes Service. The server name or address could not be resolved Error: 0x00100006. I can use it through Internet Explorer and with other browsers. When I reboot the software, I can get into the main interface but when I press the 'note' key, the error message above shows again. Can somebody please tell me what is causing this problem? Thank you.
Could not log in using Evernote on my Dopod
Hallop Michael Martin,
The first thing that I will suggest that you do is try refreshing your windows mobile application by restarting it and see it the problem will be solved. Also check the settings if there are any configured for your windows mobile, because they might be configured wrongly hence causing the problem.
If the problem persists, then I will advise that you try setting up a new account and see if it connects without bringing problems like the old account. Check also the passwords you are using, because you may be trying to use the wrong password which is causing the problem that you are having.
__
Regards
Mahesh Babu
