Could not maximize Recycle Bin window
I was searching for a tool or program that can make my Windows XP Start menu to look like Windows Vista. When I found it, I tried it on my computer but I accidentally closed the window where I downloaded the tool. Due to some issues that I’m encountering, I decided to remove the tool.
After which my problem arises. When I was about to clear my recycle bin, I noticed that I can no longer opens the window of the recycle bin to its maximum size. It always opens as a small window in which I have to manually click the maximize button to enlarge the window.
What do I need to do to open it in a usual way? Is there a setting for this? Or this is another registry issue that needed my full attention. Please help.
