Could not open the video part of the file
I often use favc to convert the movie into DVD but I keep the files so that I may work with TMPGEnc 3.0 Xpress. When I try to open these files using TMPGEnc an error occurs as you can see below. Do you have any idea the cause of the this error? I could find the resolution to fix this issue. Please suggest me to handle this problem. Thanks.
D:History.Channel.Modern.Marvels.Bunkers.XviD.mp3.NuclearAge.avi
Only the audio part can be opened.
