Could not open Widget Error
Hi experts!
I try to download this and extract to my Desktop. But when I try to open the widget   I get an Error:
"Could Not Open Widget C:UserUserDesktopB-SpecGrinder.widget. It either isn't a Widget or you don't have access to that file. (StartWidgetProcess:Unable to locate .kon file)
I have used the other one for 24 hours with no problem. I was trying to download the repair that the other guy in your other thread posted the same error I have faced. Then I stopped this one and opened the one you sent me in PM originally. It runs successfully.
I don’t know why the first one isn’t working.
They informed that the file is 26kb but I know it’s quite larger than that. Need your help. Thanks.
Answered By 55 points N/A #108553
Normally that suffers with such issues are downloading the required file to either on their desktop or in the C drive. The thing is Windows 7 and Vista has restricted access controls on the C drive so if you are not a fully admin of the system. It will occur to you every time.
When you download the file, save it to any other location other than your C drive or the desktop.
After downloading, close any other application or process that is running on the desktop.
Install the widget, it will hardly take 1 minute.
After that enable the widget by going to the widgets menu. You won't be having any problem now.
