Target: Could Not Read Field Structure
1170 points
Posted on - 06/14/2011
I am using SQL Server 08 64 BIT for Target. My problem here is, I get this error message "Could Not Read Field Structure". I already checked the services, all are running, no services seem on stop mode. I remember doing something with Target. I disabled all of the connections in the Target Management Studio Connection Manager. But I remember one day, one of the cubes failed to process, and what I did was I restarted the system, and the processes turned normal.
Could please somebody help me with this error I encountered, on where should I focus? Does the past day Cubes process failure do this? Or when I disabled the connections?
Thank you!
TARGIT
Could not read field structure
