Could Not Recognize FULIST as an Internal or External Command
I have a computer with Windows XP Professional SP3 Operating System. All the DOS programs which I have are stored in C:XEDIT, which includes FULIST.
In AUTOEXEC.NT I edited it to “SET PATH = C:XEDIT.” Since then, every time I run the Command Prompt windows, it says C:Data for example, and enters FULIST, an error pops-up. It says "FULIST is not recognized as an internal or external command, operable program or batch file."
After that, I always type “SET PATH = C:XEDIT on the command line for FULIST to work.
And every time I close the command prompt and execute it, I am force to re-type the SET PATH command which is pretty tiring.
How can I have the SET PATH activated permanently every time I boot up Windows XP?
I’d be really grateful if any of you can help me.
