Hi, I was facing some error with my PC saying that account restrictions are preventing this user from signing in. Please help me by providing me with possible answers for it?
Could The Account Restrictions Are Preventing This User From Signing In Error Be Easily Solved?
A) To fix this “account restrictions are preventing this user from signing in” issues, follow these steps:-
STEP 1. Press on the Start type Run and press the Enter key.
STEP 2. Inside the run dialog box window, write down gpedit. msc and press the Enter key.
STEP 3. In the Windows Local Group Policy Editor, go to Computer Configuration > Administrative Templates > System > Credentials Delegation.
STEP 4. On the right-hand side, find the option that says “Restrict delegation of credentials to remote servers policy.”
STEP 5. Now, double click on it and change it disabled. Press on Apply button, and then press the OK button.
STEP 6. Finally, Restart the system.
B) To fix these “account restrictions are preventing this user from signing in” issues follow these steps:-
STEP 1. Press on the Start menu button, write down Run and press the Enter key.
STEP 2. In the run dialog box window, write down gpedit. msc, and press the Enter key.
STEP 3. In the Windows Local Group Policy Editor, go to Computer Configuration > Windows Settings > Security Settings > Local Policies > Security Options
STEP 4. On the right-hand side, find the option that says “Accounts: Limit local account use of blank passwords to console logon only policy option that is under the policy heading.”
STEP 5. Now, disable it by double click on it. Press on the Apply button and then press the ok button.
