Hey guys, particularly those who are using Mac out there. Can anybody help me how to get this CS Condition Zero extreme installer work on a Mac? I found someone using Mac with this so I’m sure this is possible, just need some tips how to get it installed on Mac. Any tips would be great!
Counter Strike Condition Zero extreme installer for Mac?
Hello Mr. Isabellagregorey,
You need to get an application which allows you to use windows on your PC which meet with leopard.
But for boot camp you will need a windows install disc.
You might want to go with leopard, then after you get application and install it, then you will have to get download steam.
http://store.steampowered.com/
Then download cs condition Zero.
Thanks very much.
Hello Isabellagregorey,
Aside from the previous suggestion, I would suggest installing a Virtual Machine and install a Windows OS on your Mac. It may not be the best solution but if you have a high-spec machine it may not be a problem.
You can also try to do a dual boot with Windows but I'm not sure about the hardware compatibility. You might experience some hardware issues when doing this so do it at your own risk.
Hope this helps.
