Brad K Dorr
Posted on - 08/17/2014
I did some changes in my Counter Strike server and this error appeared when I want to import add some files. The problem is that the files meet all the requirement showed in the error. Can anyone help me please to understand what I did wrong ? How can I solve this ?
Regards !
Spray Import Error
This file’s TGA format is not supported. Supported TGA formats are 254-bit RGB and 32-bit RGBA.
Counter Strike error importing tga formats
I guess there must be something wrong with one or more of the Targa files [.tga] inside Counter-Strike which is probably using an incorrect image format. If that error is displayed and Counter-Strike only supports 24-bit and 32-bit TGA files, it is possible that one or more TGA files in Counter-Strike is in 16-bit format since TGA files can only be saved in three different formats: 16-bit, 24-bit, and 32-bit.
If you know the filename of the TGA file you are importing to Counter-Strike, open that TGA file in Adobe Photoshop and save it using either 24-bit or 32-bit format. Try the import again and it should fix the problem. You can also search all TGA files inside the Counter-Strike folder and check which ones are in 16-bit.
