Counter-Strike Source: h12.exe – application Error
Hi everybody,
I use a Radeon X850 1 gigabyte of ram and Intel Pentium 4 with 2.80 GHz processor. I run counter strike source, and I got this error. I have been using it for some time now and works fine on my PC until now when I updated.
Immediately I opened counter-strike source code it loads the menu then after that it gives me this error below.
Can I get some suggestion on how to deal with this problem?
The instruction at “0x14039e14” referenced memory at 0x0dda0f9c’, The memory could not be "read".
Click on OK to terminate the program
OK
Thank you.
Best Answer by Smith Thompson
Answered By 5 points N/A #147103
Hello Jair,
There is a file of the program which seems to be misplaced. To fix the problem you need to complete uninstall the game along with the patch files you are using and install a fresh copy of the game and the patch files.
After completing the process, Restart your computer and try to run the program.
t would run fine now.
Answered By 10 points N/A #147104
I am sorry to say that some of the game files are corrupted and your game is not running further. To solve this problem you need to first save the game data if you want to start it from where you left if most of games save games data in documents so find it and save it then uninstall the game and reinstall it to enjoy the game again.
Smith Thompson
Answered By 40 points N/A #147105
Thanks experts for your knowledgeable information. I was really becoming afraid about the error but Smith Thompson, your friendly solution assured me. Now according your advice, I have first saved the game data and followed your other instructions too. Using your solution, now I am able to fix my problem and after that I am feeling relaxed. Good solution, thanks to you and techyv as well.
