Counting GROUP BY Data in PHP
I’ve been using GROUP BY in my query but I can’t count the data being grouped. Can anyone help me on how to count the number of grouped data? Thanks.
Hello there Kenny,
Group By in SQL is not the solution to what you want to achieve. Group by function of SQL only groups your data according to the specified field you have chosen. If you want to achieve what you want, use the COUNT function of SQL. It lets you count the number of the selected field you have grouped by. To illustrate this, take a look with the code below.
SELECT au_id, COUNT(*) as “num_books” from title_authors GROUP BY au_id;
If you want to learn more with SQL you can come to this site:
Hope this helps you,
Regards Roland.
