Cover Editor is not printing
Hello
I have attempted every probable method to print disc covers by this software, but failed. After generating the design as well as layout and choosing printer etc, I see that the program will not able to connect with the printer.
But there is no problem in my printer, by other software such as: Greeting Card Factory, it prints effectively;
As a result,there is a problem with the configuration of AVS Cover Editor, i know, the problem is software related.
I need a solution.
I have uninstalled and also removed it from the registry but no luck.
Also i have re-installed it but same problem.
Please help.
Thanks. Â
Error:Â Cover Editor not printing
