Coyote.ferrus.net Secure Connection Failed (Error code: (sec_error_untrusted_issuer)
Hi fellows,
I have started using the coyote. ferrus. net mail server but I am getting the following error on my screen.
The screenshot of the error is as follows:
The error states as:
coyote.ferrus.net uses an invalid security certificate.
Tile certificate is not trusted because it is self signed.
• This could be a problem with the servers configuration. or it could be someone trying to impersonate the several.
• if you have connected to this server successfully an the past, the error may be temporary, and you can try again later.
I have searched a lot for this error on the internet, but I could not find a solution to the problem. has anyone else encountered such a problem before? If yes please do help me out.
I'll be looking forward to hear from you soon.
Thanking you loads.
Regards
Araceliariana
