nielsmel
20 points
Posted on - 08/05/2011
Hello to all readers,
I am sharing here for everybody to read about my problem while using C Query, I pasted the screen shot of the error for better view and analysis of my problem.
CQuery
PModDBase:
[Microsoft][ODBC Microsoft Access Driver]Numeric value out of range (null)
Ok
I am just a newbie in using C Query, that is why this is the first time I have seen this error message, I asked for some help from my peers but they don't have any idea about this error message. Please share your ideas on this error message that will help me solve this issue, all your ideas are greatly appreciated. Thanks a lot for reading my post.
CQuerry Numeric value out of range
If this is the first time that you have encountered this error, try restarting your computer and then run the application again. If it still generates that error, run a disk check on your computer to see if your system has an error that is causing the application to generate this error and to not work properly. If you have a disk utility application installed on your computer, run it to check your hard drive for errors. Or if you don’t, just use Windows disk check instead.
Right click on drive C and then select Properties.
Click Tools tab.
Click Check Now.
Check Automatically fix file system errors and then hit Start.
After the disk check run the application again and see if it works now. If it still displays that error, try uninstalling cQuery and then install it back to restore its settings back to default. Launch the application again. If the same error is generated, check your work if you are putting or entering an acceptable value.
