Crash while using ‘Find’ function in DesignCenter
Hi, I have just experience the following problem – 'Failed to parse XML property', when using the 'Find…' function in DesignCenter.
"Runtime
Faild to parse XML property.
Error description:""(null)"".
Source of error:""(null)""."
Has anybody else come across this? When it shows up, I click OK and it just appears again. It repeats this up to 10 times! Then it just crashes. Then, if I load it again, it might only happen once.
I have noticed that the find button can’t seem to find things in scripts related to the runtime out connector settings.
I’m going to do a reinstall. I will update you then, or if you have any tips, they are most welcome!
