Crazy birds game for samsung wave 2 is not working.
Crazy birds game for Samsung wave 2 is not working. File supported error occurs when trying to run crazy birds game for Samsung wave 2. What should I do to make the game run without any error? I wish you can explain the main cause of the problem.
Kristin Runaldou.
Answered By 0 points N/A #184420
Hi Kristin!
Did you download the game from the Google Play Store or the Android Market using your phone? If yes, uninstall and reinstall the game. It is possible that the game didn’t download properly and the file is corrupt.
If you downloaded the game somewhere else in the web or someone sent you the installer, then it is possible that the version you have is not compatible with your phone. Using your phone, go to Google Play Store or Android Market. They can detect the device you are using and will give you the appropriate version supported by your phone.
