I have downloaded all 4 ZIP files for 11.1.1..3 Windows 32 bit version, but was unable to unzip file named "bi_windows_x86_111130_32_disk1_2of2.zip". When getting to last file:
../bishiphome/Disk2/stage/Components/oracle.bi.xdo/11.1.1.3.0/1/dataFiles/filegroup1.jar
It prompts the message:
CRC failed, file is corrupt
Does anyone have any idea where to get correct ZIP? Please help me and tell me what is wrong here?
Thanks in advance.
“CRC failed, file is corrupt” error while unzipping file
I know the problem that you have experiencing I would be willing to help you on your problem.
The part "bi_windows_x86_111130_32_disk1_2of2.zip" you have to redownload this file it might have been corrupted or this is an incomplete download please check the size of the downloaded file and the actual or estimated size of the file when you will be downloading.
To avoid data corruption I would like to recommend you to use Internet download manager this is a program that will help you to avoid having incomplete downloads (this is not a freeware). But if you want you can still direct download it.
