Create and Edit Themes on Symbian Phone Using Blue FTP
Seems that you have a misunderstanding. Blue FTP stands for "Bluetooth File Transfer Program Protocol"
Basically, Blue FTP is a mobile java application which focuses on transferring files through Bluetooth connectivity. Blue FTP enables you to browse files on your phone memory as well as your memory card like PC. Using Blue FTP you can rename, cut, copy, paste, change the properties of files, send files through the Bluetooth with in the application. The main advantage of the application is that you can browse your friend's Bluetooth. It acts like a Bluetooth intruder’s application. You can browse and download any data from a paired Bluetooth device. The latest version of Blue FTP have the feature to lock the application by password. So that nobody can open the application without the exact password. You can't create/edit themes using this application.
Hopes everything is clear now.
Have a nice day!
Here is how you can create themes using BlueFTP.
And that’s it. Remember that this is only done with Java phones.
