Create Avg diagnostics for firewall
Hi Experts,
I have installed the AVG 2012 and please help me to create Avg diagnostics for firewall output. Please send me the proper solution for Avg diagnostics. Thanks.
Woodie Jerri
Hi Experts,
Woodie Jerri
Hello Woodie
You can follow the following steps to perform the diagnostics:
1. Download and install the AVG Firewall diagnostics (2013|2012) utility.
2. Run the avgfwdiagx.exe file.
3. Press 5 and hit the Enter to Create Diagnostics Package.
Hope this helps.
Happy Computing.
Jack Hostler
Hi Jerri,
It is a little problem and you can solve this issue by going through my instructions.
1. And first you have to install the AVG firewall diagnostics software.
If you don't have, please download it from https://www.softpile.com/?s=avg-anti-virus-plus-firewall
2. Click on "avgfdiagx.exe" and run it.
3. Click on 5 and press enter. Now see, your diagnostics will create automatically.
Notifications
