Create backup dvd asus to put backup files
Today my new laptop is prompting me to create backup, So how can I create backup dvd asus to put backup files?
Hi there,
In creating backup files, especially when you want to backup lots of files on your computer, you need to have multiple DVD’s or much better if you have an external hard disk drive with high capacity.
To back up your files,
· First click My Computer.
· Right-click local disk (C:).
· And click properties.
On local disk C properties, click tools then click “Backup Now…” button.
After clicking, a Backup or Restore Wizard will appear. Click next.
All you have to do is read the instructions and click next button up to finish button.
There’s also another way of backing up files when you want to backup only specific files.
You just have to copy the files and save in the DVD or burn it using the Disc Burner you are using in you Computer.
Note: Number of DVD’s depends on the size of the files you want to back up. You have to check size of files you want to back up and the free space of the DVD.
Hope it helps.
Notifications
