Hi Guys,
I was asked to create banners in flash using CS3. I placed some basic animation to it. The banners were made successfully with all the animations in CS3 but why is the animation gone when the banners were used? Has anyone encountered this problem?
Thanks,
Samantha
Create banners in flash with animation using CS3
Check your banner if the animation still working in CS3. Make sure that you installed Flash player in your Computer. Open the original file where you can still edit the banner and check if your work is really working then save it again with .GIF. I have an animated banner to my website that I created and .A GIF file is working.
When creating a flash banner you should make sure that you always save it as .GIF or Graphics Interchange Format. This format supports animation which allows a separate palette of colors for each frame. It used usually for small animations and low-resolution only. And after you save it as .GIF you can view the result but keep in mind that this format usually needs and adobe flash player to function the animation properly.
