To create a collage with Auto Collage
Auto Collage error: why this error message comes into view? I wish to solve it for the reason that I want to run the program:
Auto Collage requires at least 7 images
‘Auto Collage
To create a collage with Auto Collage, select 7 or more photos and try again.’
Answered By 10 points N/A #174351
Hi Tony S Boudreau,
May be you convert the trial version of software to full version. Most of the time this error occur for it. There is only one way I know, you must be purchase that auto collage program. If you think you uninstall this and again install it still it will not work. So, the best solution is purchasing the collage program.
Best of luck
