kevin rith
20 points
Posted on - 08/22/2012
I am working in ssrs 2008 R2. Using sql database tables as data source I have created a map report successfully. Now is it possible to create a map report using analysis service-cubes as data source?
Please share the steps if there are any ways of doing it.
Thanks in advance.
Create a map report using analysis service-cubes as data source
To create a map report using analysis services-cubes as data sources, you have to use Report Manager or Management Studio.
To create data source from services-cubes analysis you have to use Report Manager.
From "Report Manager" you will find "New Data Source". Use your services-cubes analysis as the data source & deploy it to become a report model from "SQL Server Reporting Services".
