Create New Folder in Pictures Library
Hello All,
I am failing to create folder in Picture Library. There is no “New folder” button in the Explorer. How can I fix this problem?
Do I need to reinstall Windows 7 again?
Thanks in advance
Best Answer by CherylDequa
Answered By 0 points N/A #120294
Firstly are you trying to create a new folder in a restricted folder? If you indeed can’t create a new folder in your own pictures folder, some program/virus has changed the properties of your My Pictures folder, you can easily gain control over your My Pictures with a simple trick. Firstly you would need to download a small file of 622 bytes from this link https://www.facebook.com/permalink.php?id=220167578171658&story_fbid=1408215969425944
 It has two small registry files in it with the extension .reg. You need to open the file that says ‘InstallTakeOwnerShip.reg’ and click yes if a window appears that warns you that your registry is being changed, it is safe so click yes. After that navigate to your My Pictures folder which is located in ‘ C:Users<your windows account name>My Pictures ‘ right click on the My Pictures folder and click on ‘ Take Ownership ‘ it will transfer the rights of that folder to your account and you will be able to make new folders again.
Answered By 0 points N/A #120295
here is my trick
copy the content below and paste on new  notepad document and then just save this file as fix.reg ,,remember .reg extension is a must because then only u can make changes to the registry which is in your case is corrupted.. and when u have saved this file on your computer as a registry file then double click and select run after it and i guarantee your problem is solved.. cheers
Code starts after this!!!>>>
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOTCLSID{11dbb47c-a525-400b-9e80-a54615a090c0}]
@="CLSID_ExecuteFolder"
[HKEY_CLASSES_ROOTCLSID{11dbb47c-a525-400b-9e80-a54615a090c0}InProcServer32]
@="ExplorerFrame.dll"
"ThreadingModel"="Apartment"
[HKEY_CLASSES_ROOTDirectoryBackgroundshellexContextMenuHandlersNew]
@="{D969A300-E7FF-11d0-A93B-00A0C90F2719}"
[HKEY_CLASSES_ROOTFolder]
@="Folder"
"EditFlags"=hex:d2,03,00,00
"FullDetails"="prop:System.PropGroup.Description;System.ItemNameDisplay;System.ItemType;System.Size"
"ThumbnailCutoff"=dword:00000000
"TileInfo"="prop:System.Title;System.PropGroup.Description;System.ItemType"
[HKEY_CLASSES_ROOTFolderDefaultIcon]
@=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,00,25,
  00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,73,00,68,00,
  65,00,6c,00,6c,00,33,00,32,00,2e,00,64,00,6c,00,6c,00,2c,00,33,00,00,00
[HKEY_CLASSES_ROOTFoldershell]
[HKEY_CLASSES_ROOTFoldershellexplore]
"MultiSelectModel"="Document"
"BrowserFlags"=dword:00000022
"ExplorerFlags"=dword:00000021
[HKEY_CLASSES_ROOTFoldershellexplorecommand]
  00,5c,00,45,00,78,00,70,00,6c,00,6f,00,72,00,65,00,72,00,2e,00,65,00,78,00,
  65,00,20,00,2f,00,73,00,65,00,70,00,61,00,72,00,61,00,74,00,65,00,2c,00,2f,
  00,65,00,2c,00,2f,00,69,00,64,00,6c,00,69,00,73,00,74,00,2c,00,25,00,49,00,
  2c,00,25,00,4c,00,00,00
"DelegateExecute"="{11dbb47c-a525-400b-9e80-a54615a090c0}"
[HKEY_CLASSES_ROOTFoldershellopen]
"BrowserFlags"=dword:00000010
"ExplorerFlags"=dword:00000012
[HKEY_CLASSES_ROOTFoldershellopencommand]
  00,69,00,64,00,6c,00,69,00,73,00,74,00,2c,00,25,00,49,00,2c,00,25,00,4c,00,
  00,00
[HKEY_CLASSES_ROOTFoldershellex]
[HKEY_CLASSES_ROOTFoldershellexColumnHandlers]
[HKEY_CLASSES_ROOTFoldershellexColumnHandlers{F9DB5320-233E-11D1-9F84-707F02C10627}]
@="PDF Column Info"
[HKEY_CLASSES_ROOTFoldershellexContextMenuHandlers]
[HKEY_CLASSES_ROOTFoldershellexContextMenuHandlersBriefcaseMenu]
@="{85BBD920-42A0-1069-A2E4-08002B30309D}"
[HKEY_CLASSES_ROOTFoldershellexContextMenuHandlersOffline Files]
@="{474C98EE-CF3D-41f5-80E3-4AAB0AB04301}"
[HKEY_CLASSES_ROOTFoldershellexContextMenuHandlers{a2a9545d-a0c2-42b4-9708-a0b2badd77c8}]
[HKEY_CLASSES_ROOTFoldershellexDragDropHandlers]
[HKEY_CLASSES_ROOTFoldershellexDragDropHandlers{BD472F60-27FA-11cf-B8B4-444553540000}]
[HKEY_CLASSES_ROOTFoldershellexPropertySheetHandlers]
[HKEY_CLASSES_ROOTFoldershellexPropertySheetHandlersBriefcasePage]
[HKEY_CLASSES_ROOTFoldershellexPropertySheetHandlersOffline Files]
@="{7EFA68C6-086B-43e1-A2D2-55A113531240}"
[HKEY_CLASSES_ROOTFolderShellNew]
"Directory"=""
"IconPath"=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,
  74,00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,73,
  00,68,00,65,00,6c,00,6c,00,33,00,32,00,2e,00,64,00,6c,00,6c,00,2c,00,33,00,
  00,00
"ItemName"="@shell32.dll,-30396"
"MenuText"="@shell32.dll,-30317"
"NonLFNFileSpec"="@shell32.dll,-30319"
[HKEY_CLASSES_ROOTFolderShellNewConfig]
"AllDrives"=""
"IsFolder"=""
"NoExtension"=""
