Create new java project using JCreator Pro
How can I create a new Java project using JCreator pro and how can I run my codes? Please teach some procedures on how doing this. Thanks
Dear Olivia Rodriguez,
You are using JCreator pro for a new Java project. Now you want to know how to run the codes. Here some lessons, you may follow this. Hope all my tips will help you.
To install JCreator you can follow the instruction on the link below-
*http://www.cs.cornell.edu/courses/cs211/2006fa/IDEs/jcreator.html
Here is a link of some lesson about JCreator which will help you.
1. http://www.horstmann.com/bigj/help/jcreator/index.html
Both the links having well explained about JCreator and Java which you want to learn.
I hope all my information will help and you can run Java code.
Thank you.
