Create Online Purchase Order Form using the Java Programming
I need to create an online purchase order form using the Java Programming. What are the codes to create this or the procedures on how to achieve this. Thanks.
Hi, Rchandra,
As I know you want to create an online purchase order form for the U-Built-It Hardware Company. You can easily do so just refer the attached file here in with my reply.
The attached file contains a program to create an online purchase order form for the U-Built-It Hardware Company. Just open the file to find extension, run it and you can see your Online purchase order form as the output.
I hope this will fix the problem.
Thanks & Regards
Gillam Janetj
