Dear Techyv Users,
I am in need of coding to create paint brush using Java swings. Please do the needful for providing the coding for creating paint brush, so that I can understand the Java coding.
Thanks & Regards,
Bennie S Easter
points
Create paint brush using Java
Hi Bennie S Easter,
It is a simple java applet application of a pain-brush style program. To create paint brush using java swings need coding so visit this site. Here you will get how you will be able to create a Paint Brush application in java swings.
In this application simply clicking and dragging the mouse you can paint a line on the window. To do that at first create a class PaintBrush.java extend from JFrame class as a frame represents a window with a title bar and boarders. Then, simply create another Java file named MyPanel.java and compile the both.
For more info also visit this site too.
Enjoy your program! Â
