Create a script of custom scrollbar html Mac
Need a JavaScript for custom scrollbar html mac. The Script should have a CSS an could work on different sizes of screen and different sizes of data. It should be function in all matters of uses on Mac os.
Best Answer by Glenn Mcgaughey
Answered By 0 points N/A #162366
A scrollbar is very important for the user to navigate a website. It is also acknowledged as Handle in the first Graphical User Interface or GUI. In making or designing a Scrollbar, you can use a JavaScript or CSS. I will show you some tutorials in making Scrollbar.
1.   jQuery is a plug-in that you can customize with CSS.Follow the link for the complete tutorial and User Guide:
 http://manos.malihu.gr/jquery-custom-content-scroller/
2.   This Scrollbar is in JavaFx.
http://blog.ngopal.com.np/2012/07/11/customize-scrollbar-via-css/
3.   Scrollbar that is made by Tim Holman.
http://cssdeck.com/labs/css3-webkit-vertical-scrollbars
Answered By 0 points N/A #162367
Hi.
Making scrollbar with JavaScript is quite simple. You don`t have to worry about technical details. Scrollbar in HTML is an boy that adds the scrollbar to the web site windows. To write an scrollbar you need first to define it in HTML code. When scrollbar is defined then make his look in css and after that you can connect elements with JavaScript. Below in attachments are some code samples for you.
Queen Norman
