Hello experts,
What is all about creating client login? Suggest the best programming language to create a log in administrator environment and followed by the coding setup. I would like you to suggest the best one between, java, visual basic, programming c language and c++. And also explain the advantage of each programming language, thank you.
Create a Secure Client Login Area with Programming Codes
Hello Chloe,
If you’re all familiar with java, visual basic, programming c language and C++ then my best suggestion is that it’s Visual Basic.
Why Visual basic?
Visual basic of course about its GUI (Graphical User Interface) and DAD (Drag and Drop) functions you can easily create a client login with an ease and you'll just add the codes to the buttons and textfields. Unlike C++, Java, and Programming C language you yourself need to create codes for its frame and log in form.
In my knowledge the best and most superior programming language for creating client login is Java. The reason is because it allows adjusting the schemes on CSS files and client-side authentication and also jquery allows dynamic interchange of data between client and server.
