Create a table in word.
Hi
First of all, Click in the cell where you want to display the total of the numbers, then Click the "Table Tools Layout" tab. Click "Formula" in the Data grouping. then Enter your formula. To tally the numbers in the column above the formula, for example, you would type: =SUM(ABOVE). You can replace "Above" with "Below," "Left" or "Right," depending on the location of the numbers you're adding. In the End, Choose the number format you want to.
cheers 🙂
Using auto sum is Ms Word is easy, you will just need to use the procedure below:
Just an example on how to implement auto sum, in case you need to sum the units that are sold in the north by all representatives, then you will just need to click the blank cell which is just below those values and then you will click AutoSum in the Ms Word menu. AutoSum will automatically add up all of the values above the current cell.
-Clair Charles
