Create watermark in photo explosion
Hello Techyv Guys,
I would like to create watermark in photo explosion with the help of a freeware, which will consume less space in the system. Please do the needful for suggesting a dedicated freeware that will have an option to add watermark in photo explosion.
Thanks & Regards,
April Rosas
Best Answer by Fletcher Hoss
Answered By 0 points N/A #151343
I have a procedure that could help you create a watermark in Photo Explosion though you will not need to use a freeware. The following is how you go about it.
  • First, you will need to launch Photo Explosion in the Image Editor.
  • After that, open a copy of the Ferris Wheel Image and then right click on the background layer that is found on the Layers tab.
  • After that go to the Pop Up Menu and then choose "Promote to Layer". The background image should change to Layer 1 and the Opacity will be accessible.
  • Lower the Opacity to the desired result and then click on the Text Tool on the tool bar.
  • Click where you want the image to appear and then adjust the font type and size.
  • Type the text above the image and then save the file.
  • Make sure that you save it with *.Pex extension and then export it, and then save it with whichever format you want depending on the program you are using.
Fletcher Ross
Answered By 0 points N/A #151344
Hi April Rosas
The recommendable software that could help you carryout an amazing task from your digital images is Photo Explosion Deluxe which offers a comprehensive suite of tools designed for digital images, this remarkable program helps you to manage your collection, edit, enhance photos and more so share them through Email or on a CD. For more valuable great features about this software visit Watermark Deluxe.
