Creating A New Exchange 2007 Send Connector In Your Database
How to create a new exchange 2007 send connector to manage all the files and data in my system and to be able to send and connect to different databases.
Send connectors are used to connect e-mails to remote servers so that you can access them wherever you like if it is connected to it. These kinds of tasks are performed only be the registered delegates of exchange organization administration. The procedure to be followed for exchange 2007 send connector is –
1.) Click exchange management console > edge transport > send connectors. Create a new send connector.
2.) While asking for an introduction, you have to fill up the certain fields required for the send connector creation. Click next.
3.) Fill up the fields required on the address page and click next. Moving to the network settings, select the required settings and click next.
4.) A pop-up window will appear showing the status of the send connector. Check the fields and amend if needed. Click ok.
