irfanowaisi
Posted on - 02/26/2012
Hello to all TECHYV experts,
I am trying to make an account on MICROSOFT OFFICE OUTLOOK 2007, but it always failed on connecting to server. Please describe me brief way to create an account and use of Outlook 2007.
Thanks in advance friends.
Creating account in Microsoft Office Outlook 2007
Here are the steps on how to create an account for your Outlook 2007:
Open the Outlook by selecting Account Settings under the Tools menu.
Once on the Email tab, click on New.
After that, select Manually Configure Server Settings or Additional Server Types then click on Next.
This time, select Internet Email then click on Next.
Then enter all the information below:
Your name – this is the name you would like the receiver or recipients to see when they receive your message.
Email Address – this is your contact email address where the receiver can send you a reply.
Account type – POP3.
Incoming Mail Server – pop3.ivenue.com.
Outgoing Mail Server or SMTP – smtp.ivenue.com.
User name – this is your full email address.
Password – make sure your password is strong but something that you can easily remember so that no one else can access your account. You may also check the box labeled Remember Password if you don’t want to type it every time you are going to access your account.
Click More Settings.
Click on the Outgoing Server tab this time then check the box that says “My outgoing server (SMTP) requires authentication”. Once done, choose “Use same settings as my incoming mail server”.
Now, click on the Advanced tab.
Under “Incoming Server (POP3), make sure that the port number is set to 110.
Under “Outgoing Server (SMTP), you should have 587 as your port number.
This time click OK.
Then Next.
Then Finish.
